Coleman 550 front couplings and splines
Popular Now
By paul allen
right front axle cv joint boot keeps getting torn up from the inside out....the stock one was damaged from a stick...i have replaced the axle 4 times with aftermarket axles that fit fine..after 4-5 miles of riding even on grass.the outer boot get torn up from the inside out...all 4 brand new alxes...bearings are fine nothing bent everything fits just fine....nothing seems to be binding.....any thoughts?????
thanks...pa
By Bedlam
Hello,
I have a 2019 Landmaster 550 UTV. Its been running good until now. The front axle wont engage. Where I live the temps have been well below freezing. The UTV is stored in unheated garage. And even the bottles of stored windshield washer fluid are frozen solid. So I am thinking that the front axle gear oil might be VERY thick and now allowing it to engage. Off the front diff is a small gauge wire running up to a connector. I put a test lamp to one of the leads and with utv running and 4 wheel switch on there is no voltage. However if I shut it off and have the 4 wheel switch engaged. and the crank it to start again the light gets a signal. for a second or two. I have to jacked up on rear and front and sometime the front will cut in and spin a few revs but the drops off.
Im hoping that someone can explain how the front engages on the axle. I assumed there was a fork or something that was engaged with 12 volts. But this wire is very small .This unit doesn't have a central fuse panel but I believe I have checked all the fuses.
Thanks in advance
Allan
By Paul O
I boughtba new Hisun HS 500. When I press the red 4wd button the icon over the front differential on the display flashes. Is this normal?
