I have a 2016 Landmaster 670. It will stop running after 15-20 of driving. Restarts easily but still has a hard time staying running after that. New carburetor, fuel pump, fuel filter, and spark plugs. Anybody else have this problem?
  • Alex changed the title to 2016 Landmaster 670 stops running after 15-20 Min
Could it be a plugged fuel line? Maybe crimped?
Have had that happen before. It will fill the bowl up but it barely passes gas so it won't keep up once the bowl is empty.
 Could be at the tank end also.
My two cents anyway, good luck.
I'm having the same problem with a 2014 LM500, with 479CC Vanguard engine. I haven't changed the fuel pump yet, the Carb, was repaired a few months ago and was running just fine. It is doing the same thing now as before, I had a guy do some maintenance on it. I think I'll take the advice above and check the fuel lines also, it will only run for a few seconds and then shuts off.
    • By Sammy
    • By jertex
      I have two questions:
    • By Jeff freeman
    • By BWF
      I have a 2011 or so Landmaster LM200.  I cannot get it to start.  I turn the key and nothing happens.  The brake switch seems to be working, the ignition switch works.  The Coil is new the Voltage Regulator is new and the starter relay is new.
      I can connect the terminals on the starter relay and it starts right up and runs fine.  I just can't get it to start by turning the key.
      I am having a bit of trouble bleeding the brakes, not much fluid comes out at the calipers when I am pumping the brakes, though that an air bubble near the brake switch might make it not sense that the brake pedal is depressed.
      I am at a loss, please help!
      Brad
