The main aluminum gearcase on the rear that the electric motor bolts to actually broke in half.  I found the replacement part number from Hisun University Manual.   I ordered a replacement gearbox from a dealer in Kansas, IIRC (they were the easiest to actually source it from and talk to.  I think it cost about $1100).   I thought the process to replace it would be horrifying but it was actually fairly straightforward.  A reasonable mechanic should be able to complete it in one day.   the rear axles/tires/suspension DO NOT have to be removed in order to accomplish the task (but the splines are retained by small retaining springs to they wont just pull out you have to "shock them out" with a screwdriver/wedge/tap with a hammer operation).   everything else just unplugs and unbolts ,  reverse the process and you're finished.  keep the phase order correct to the motor (it is 3 phase ac induction type motor).   there is an encoder (for speed feedback) and a thermistor on the back of the motor you have to unplug.   I thought it would be worse than it was and you can do it single handedly.   just thought I would share for anyone going through the same process.
    • By AlphaSerenity
      Hello,
    • By mrpro
      I got the fronts adjusted.  I'm trying to raise the ride height in the rear, but my spanner wrench keeps slipping.  Is there an easier better way?  It's like there's too much pressure working against me to be able to twist the height adjusters.  How can I relieve that tension to make them easier to turn?
    • By Bucky4444
      Has anyone found a decent replacement for the factory mirrors on a 2020 1100C?  My 2011 1100 and 2020 1100C both have the same mirrors and Kubota hasn't made one improvement to the design during those years.  Haven't checked the newer models so maybe Kubota finally woke up. Mine are definitely in need of improvement.  .
    • By mike28honda
