Massimo MSU500 no start condition
By Skeeter22
By Nick Varnes
So I have a Bennche Bighorn 500 that I bought used a couple years ago. Was working fine until this winter when I was plowing and I think it drained the battery. And had a difficult time starting and staying running. Idle seamed really low, and would only stay running if I pushed on the throttle. So I changed the battery, and the acm valve, fuel filter and spark plug it will start up and surgery to 3k rpm but comes back down and dies, unless I give it throttle. I am getting fairly good amount of fuel from fuel pump. It does spit at stutter right before it dies. What should I try next?
By Cliffampranch
I have a 14 mile round trip on level roads to reach the property where I work with my 2025 Amp Crew Ranch (purchased, April 2026). That 14 mile round trip uses 60% of the battery as shown on the gage for a calculated range of 23.3 miles versus an advertised “up to 50 miles” range. A mile or two working on the property gets me a flashing gage and warning beeping by the time I get home. The dealer was good to work with and even with a new battery (yesterday) the results were about the same, although there seemed to be more power and a higher top speed. I own a Mach-e Mustang so I am familiar with how various conditions affect range, but less than 50% of advertised range just seems like there has to be something out of whack.
Now I’m wondering if there is a controller and/or software issue affecting the range and performance. At various points the Amp seems to lose power for no reason and then has trouble maintaining speed. Any ideas?
Also, twice now, the brakes seem to have not released fully. After noticing reduced speed, I stopped and check the rotors and wheel…..HOT! So, now every time I feel less power, I stopped to cycle the brakes and check the temperature. Very annoying. Are there any adjustments to be had?
Lastly, while an electric vehicle powertrain is quiet, my Amp was horrible from a road noise and vibration standpoint. This was easily fixed by locating panels vibrating on other panels or the frame (even the cup holders were vibrating) and installing felt adhesive pads at the contact points (seat to frame, windshield to frame, fenders to frame, etc.). This is a $10 and 1/2 hour fix that makes a significant improvement in the driver/passenger experience. Tire noise, yes, but that’s because of the knobby tread.
By Eman85
