2020 UT400 surging after sitting for winter
Popular Now
By BWF
I have a 2011 or so Landmaster LM200. I cannot get it to start. I turn the key and nothing happens. The brake switch seems to be working, the ignition switch works. The Coil is new the Voltage Regulator is new and the starter relay is new.
I can connect the terminals on the starter relay and it starts right up and runs fine. I just can't get it to start by turning the key.
I am having a bit of trouble bleeding the brakes, not much fluid comes out at the calipers when I am pumping the brakes, though that an air bubble near the brake switch might make it not sense that the brake pedal is depressed.
I am at a loss, please help!
Brad
By Dave Jones
So with seat belt on I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
By Kierobi
Have a MSU 500 that we got from my wife's uncle a while back. We've had it running and hauling around the property but it stopped a few months ago after what I thought was running out of gas and I'm just getting to looking into it.
Had fuel to the injector but nothing coming out the injector so swapped with new injector and installed inline filter in the supply hose from fuel pump. Tried again and still nothing but noticed this time that I can't hear the fuel pump priming.
Pulled off the electrical connection and I'm getting 12V to the fuel pump but it won't run. Put it on a test bench and got it to run so put test lamp between +ve and -ve terminals on the connector and nothing. Checked against the passenger seat securing post and get a light.
Tried chasing the wire back and think that the ground is through the ECU but not 100% sure. Can someone confirm for me? And if it is through the ECU, is the ECU just grounded against the frame or is it wired through to the battery?
Thanks in advance and hope this all make sense!
By Butch
I have a AXIS 700 EFI Fuel pump pressure stays at 40 psi and when return line is blocked the pressure goes to 60 psi. and wll only run with return line closed.
By Jeff freeman
I have a Coleman 550. Was having problems to start with where it would start and then shut off after a couple tries. It would take off and be good. It then got to a point where it would not start at all. I replaced the fuel injection twice the second time I replaced it I noticed a mouse or something had chewed one of the wires that connect the electrical to the fuel injector. . So two-part question first does anybody have a part number for that wire harness? Second, any other ideas after I fix the wire harness permanently on what could keep it from starting I have gas flow up to the fuel injector.
