 Other than maybe the governer needing adjusted I couldn't tell you. I believe the older ones are rated around 25mph so it should go that fast.
Are you going by the dash speedo which some aren't exactly the most accurate or a phone app or something. I have a phone app speedo for when I drove my PU that was way off and it worked great. It looks like you have larger tires so that will drop the speedo a bit? It might be the camera angle but the fronts look quite a bit larger than the rears? I know some had different tire size set ups and some were the same front and back.
 Try going to American Landmaster online and check out the manuals and they should have all the info to double check. I would download everything you can just for future reference. Check the motor and such you have now as most manufacturers will change motors for cheaper prices or when having issues. On my '22 L5W I was able to download the engine, tranny, frame and axles specs. I probably won't split anything but it will give me an idea where or what to look for if anything goes wrong.
 If you want, check the size of your headlights and checkout the newer LED headlights sizes they use now as they are AWESOME. They would definitely be a great upgrade retrofit.
Yup, forgot about that, some of them you have to have the seat belts connected. Usually just connecting the seat belts will work or you may have to diagnose it.
 If you still have your manual it should say if it has it or not as it will say to connect them.
    • By AlphaSerenity
      Hello,
    • By OBL
    • By Eman85
    • By Jeff freeman
    • By Alex
      What’s Included?
      Why the RANGER XD 1500?
      Entry Information
