Fuel pump and cooling fan inop. I have the fuel pump hot wired that keeps me goin but now cooling fan wont kick on. I'm bout to look for a scanner hook-up unless someone can give me direction, any help?
Have you checked the circuits with a meter?  There are fuses that may have failed, and while I'm not sure about your machine in particular, there may be fusible link wiring in the circuit.   That wiring is ofter (but not always) tagged as such so it can be identified quickly.
It takes some patience but if the fuses on these circuits are good, use a meter to check all wiring and connectors "downstream" from the fuses.   At some point you will find a dead spot where the power fails to continue to those items.
Good luck.
    • By Sammy
    • By OBL
    • By Mountainman
      Radiator fan on 2018 textron havoc won’t come on
    • By Jeff freeman
