Fuel pump and cooling fan inop. I have the fuel pump hot wired that keeps me goin but now cooling fan wont kick on. I'm bout to look for a scanner hook-up unless someone can give me direction, any help?
Have you checked the circuits with a meter?  There are fuses that may have failed, and while I'm not sure about your machine in particular, there may be fusible link wiring in the circuit.   That wiring is ofter (but not always) tagged as such so it can be identified quickly.
It takes some patience but if the fuses on these circuits are good, use a meter to check all wiring and connectors "downstream" from the fuses.   At some point you will find a dead spot where the power fails to continue to those items.
Good luck.
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
    • By Kierobi
    • By Butch
    • By Jeff freeman
    • By Eman85
      Pulled fuel injector to see if I could clean it or if it's stuck open. Had a slide on clip that was really tough to get off. Don't see how the clip is supposed to lock into the plastic part that the injector slides into. Any videos or pics of injector replacement?
