2024 Segway Villian Overheating Shuts Down
By carbdoctor
I have an 850. It’s been overheating. The electric fan is not kicking on. I see the temperature switch going into the radiator, but there’s no wire plugging in to it or none to be found in the area. i’m thinking I might’ve hooked on a branch and it ripped out the harness on that part. Does anybody have a picture or no where that plugs into on the harness? On the top of the firewall, I did notice some plugs that have nothing plugged into it. I was wondering if it’s a harness that goes from there down to the radiator that was pulled off
By Rmillerdesigns
Hello. I have a 2016 Massimo MSU 500. I was putting on a lightbar and i screwed up and didn't disconnect the battery so when i was taking of the positive cable to put on the power from the lightbar it sparked and now the utv has no power. I turn the key over and all i hear is a chirp. No lights or anything. Everything that comes from the battery to the jumper box up by the battery shows voltage but anything coming out does not such as to the winch or anything like that
By J Cardwell
Purchase a few weeks ago runs great for a short period of time, say 10 minutes. As soon as I get up the trail temp jacks and power drops to creep mode 1st gear 8mph.
By oakhill
When I am moving forward on my Hisun 500, the motor accellerates up and down while I have my foot on the gas pedal. It also is not idling very well. Both symptons appeared at about the same time. What should I look for? Thanks.
By Surfalia
Just purchased this Old Hisun and it included with a box with a brand new EPS kit. I found YouTube University installation videos and it looks doabke, but maybe the kit is made for newer models because mine doesn't have any extra open plug and play wires I see in the videos that woukd allow me to seamlessly connect the EPS wiring harness too. Has anyone ever retrofitted an EPS kit to a 16 year old model?
Thank you for any usable input offered.
Sincerely,
Surfalia
