2024 L4 Landmaster nightmare
By mike28honda
By BWF
I have a 2011 or so Landmaster LM200. I cannot get it to start. I turn the key and nothing happens. The brake switch seems to be working, the ignition switch works. The Coil is new the Voltage Regulator is new and the starter relay is new.
I can connect the terminals on the starter relay and it starts right up and runs fine. I just can't get it to start by turning the key.
I am having a bit of trouble bleeding the brakes, not much fluid comes out at the calipers when I am pumping the brakes, though that an air bubble near the brake switch might make it not sense that the brake pedal is depressed.
I am at a loss, please help!
Brad
By rdc
By MilSurpYinzer
Tire chains for the winter
Bumpers because duh.
Thanks so much!
By J Cardwell
2024 villian overheating shuts down to crawl mode. If I turn it off for 30 minutes power returns to normal.
