Posted (edited)
If you use Herculiner, remember 90% of the work is preparation.  Watch the utube installation videos. Also ask Lowe’s to agitate the can.  It will help.
Edited by KentC
Wrong words
I used both but I probably could have gotten by with just the brush, since it really is a small area.  I took the tie downs off as well as the rails and coated the rails separately.  But what ever you wish to do.  I was pleased with the finished job.
  • 1 year later...
I am looking for the same thing for my T-Boss 550F. I have been looking at a lot of products online; the best coatings need a lot of prep work and the cheaper ones have horrible reviews. I think the rubber mat idea is the best so far. It is fairly inexpensive and easy to remove and replace if unsatisfactory.  The coatings are very labour intensive and are very difficult to recover from.
    • By AaronD1982
      New starter solenoid....check
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
    • By AaronD1982
    • By RBonds007
    • By RBonds007
      Looking for an online parts store.  Just need basic maintenance parts tune ups and such.  Any suggestions?
