I have a new Massimo T boss 410 with 2 hours on it. I tried to start it today and I get no power at all. I tried jumping it and still no power sounds electrical problem. Any help would be great
Mine did the same thing once. Put the key in and tried to crank it over. I got nothing. Removed the battery and put it on a charger. While I was at it, I found that the cables at the battery were not very well secured, so once I got a full charge on the battery, I reinstalled it and was sure to get a tight fit on the cables. It's been good ever since. It does lose a bit of a charge if it sits too long without being started.
  • 1 year later...
  • 8 months later...
    • By AaronD1982
      New starter solenoid....check
    • By carbdoctor
      I have an 850. It’s been overheating. The electric fan is not kicking on. I see the temperature switch going into the radiator, but there’s no wire plugging in to it or none to be found in the area. i’m thinking I might’ve hooked on a branch and it ripped out the harness on that part. Does anybody have a picture or no where that plugs into on the harness? On the top of the firewall, I did notice some plugs that have nothing plugged into it. I was wondering if it’s a harness that goes from there down to the radiator that was pulled off
    • By BWF
      I am at a loss, please help!
      Brad
    • By MilSurpYinzer
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
