Buon giorno a tutti sono italiano e mi trovo in difficoltà con il mo rtv 900 viene importato con limitatore ( non va )
e nessuno sa dove trovarlo e come levarlo sotto sforzo o in salita quando si ha bisogno di motore muore come se mancasse gas
qualcuno sa come poter intervenire non mi interessa la velocità ma purtroppo va ad influire su la resa sotto sforzo grazie a tutti vi auguro una buona giornata
Good day everyone, I'm Italian and I'm in trouble with the mo rtv 900 is imported with a limiter (it doesn't work)
and no one knows where to find it and how to remove it under stress or uphill when you need an engine, it dies as if there was no gas
someone knows how to intervene I don't care about the speed but unfortunately it affects the yield under stress thanks to all I wish you a good day
Is the model an RTV 900 or a newer RTV X900? Also, if it has seat belts for safety, try hooking them together as some UTV's limiters only work when the seat belts are not hooked up.
I looked through the parts diagram and searched, the closest thing to a speed limiter i could find is the Diesel Engine's governor, and that's there so you won't blow up the engine.
i wonder if you may have some other issue where the engine can't get enough fuel to run under the load of going uphill+ what you may be carrying/passengers.
    • By Garjess
      My rtv 1140 won't turn over.  I've jumped the neutral switch, and the brake switch, and checked the ignition switch. I'm not getting any power to the trigger wire on the starter solenoid.  It starts fine with the key on and putting power to the trigger wire on the solonoid.
    • By brewski
    • By dragon
      I need help I have a 2016 Kubota 1100 RTV my tilt steering wheel locked in the upper position after using the side release. The handle works but does not release the steering wheel to a lower position. If anyone knows and easy fix, please let me know any help is appreciated. Be Safe, Thanks!
    • By dragon
      Hi everyone, I am new to the site and I have one question. My tilt steering wheel is locked in the upper position, and I was hoping for someone could help me with the problem. I did spray some WD 40 in the area of the mechanism but still wheel is locked in the upper most position. I am willing to try anything to get the wheel free and move to a lower position. Any ideas will be appreciated. Thanks!! and Be Safe!
    • By MitchSpence
      I have read where non ethanol gas is a key to some of our utv problems. Can I get an amen?
