DFK Cab
By TapBoss
So I’d been shopping for an enclosure for my ‘21 TBoss pretty much since I bought it. Then they came out with half doors and that’s the only one that I could find. Then the other day I ran across one on Amazon for half the price of anything else I’d seen. The link is below and I’m pretty impressed by how well it fits. There is one Velcro strap on the top of the door that doesn’t line up well with the roll cage, but I’ll work around it.
https://a.co/d/09ACQ191
By Adrian Domingues
Thanks for your help
By AlphaSerenity
Hello,
By Cliffampranch
By Eman85
