Thanks I found that the cable connected to brake peddle did not pull pin back to go in reverse (safety feature. Appreciate your response.
    • By Rschrem
    • By monkthumper
    • By BigWave
      Bigwave
    • By GunnersTacklebox
    • By Mike Jenkins
