'08 (I think) Renegade R2 800cc fuel injectors
By Xov
By Tim n Deb
By monkthumper
By Ed Michael
My older LM 650 is blowing fuel into the air cleaner. Any idea on what would cause this? It is the Suzuki motor. Not sure what model year it is.
Subaru SxS.mp4 -
By didgeridoo
