Oil filter?
Go to solution Solved by Mikeboz,
So I am doing the first oil change and after removing the filter I noticed a little spring and what appears to be some type of retainer that attaches to the oil filter my question is how the heck do you line that back up when you put that filter back on?
  • Solution
Okay I think I figured it out, apparently that piece should have stayed on the engine and not came off with the oil filter, so I have installed back on the engine and then put the oil filter on had a momentary brain freeze.
    • By Tim n Deb
    • By Chile
      Chile
      Any thoughts ?
    • By Joe Breaux
    • By Aaron Colona
      Just bought a brand new 760 about a month ago. I'm at 20 hours which the book says is when you need to change the break in oil.
      I must be crazy, but I can't find the oil filter. I've googled a million videos...everything seems to be 2019 or lower...and/or a 550.  They all show the filter easily seen by looking in past the rear passenger tire on the engine. There is absolutely nothing there on mine.
      1.there seems to be very little info if you Google a 760, or anything Massimo newer than like 2019.
      2. Does anyone have a current model year 760 that can answer my riddle for me?
