Tracker 800SX LE Accesory Lights
By Mitch13
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
By brewski
By Xov
By Rmillerdesigns
By MilSurpYinzer
Tire chains for the winter
Bumpers because duh.
Thanks so much!
