New starter solenoid....check
I have a 2018 TW450 that runs fine on flat ground but dies out when under load going uphill. Changed the gas filter and spark plug with same results. Letting it set for a few minutes it will run until it hits a incline. Belt is not slipping, but the engine just dies out and doesn't even want to run in neutral. Any ideas as to what I can try is appreciated in advance. Also only run non-ethanol for fuel.
So with seat belt on I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
