Blinded by dash lights?
By MilSurpYinzer
Anyone decent with electrical work that knows a good tutorial on how to make my running lights switch off all together but also turn back on when I need too? I'd assume that my lights are hard wired to the battery or the fuse panel.
Vehicle is a Kawasaki Krx 1000
I'm looking to ad IR driving lights for night vision and short of just putting black tape over the lights I feel this would be a more efficient option and it would be cooler.
By jugliner
I have a fuel injected UT400 that will start and idle, but surges and sputters at higher speed. It has been sitting for 2-3 months and was fine when parked in garage. I assumed it was a fuel/air problem and pulled the throttle body and cleaned it up. I've ended up replacing the injector, IAC valve, MAF Temp Pressure Sensor, and fuel filter. I've also checked the spark plug, Still surging. I reset the ECU after every component swap.
I plan to pull the throttle body again and look evrything over for any visible leaks, etc.
Any suggestions would be appreciated on next steps. The problem developing after sitting makes me think it should be something simple, but I'm stumped. BTW the fuel was fresh and treated with Stabil.
Thanks.
By bcorneliusen
Hi,
I have recently inherited a 2017 Mahindra mpact 1000 S Diesel flexhauler. The small silver-bezeled indicator gauge on the dash is no longer working since the wires were accidentally pulled from the back. I have managed to connect the correct wires for the seatbelt safety but most are still unplugged. Any pics or a wiring diagram for that gauge would be helpful.
By Paul O
I boughtba new Hisun HS 500. When I press the red 4wd button the icon over the front differential on the display flashes. Is this normal?
