Does anyone know if they sell a tuner for this unit to adjust AFR and timing to get a little more out of these motors without damaging them. I understand it most likely voids the warranty but still interested.
thanks, Rick
  • 2 months later...
thanks, Rick
In order to tune the MT05 Delphi ECU on the 750's, you need the following:
USB to OBD2 Port adapter
6 Pin OBD to OBD2 adapter
HUD ECU Hacker Software
I haven't found anyone that tunes the single cylinder 735cc engines.  I have been tinkering with mine but it is far from stock so I HAVE to learn lol.
CP Carrillo 11:1 Forged 102mm 660 Raptor piston
Hotcams Stage 2 660 Raptor Cam
Kibblewhite Dual valve spring kit
Kibblewhite Valve Guides
Ferrea +1mm stainless intake/exhaust valves
Ported/Polished head
Ported and enlarged intake
Hisun Tactic 1000cc 54mm Throttle body
Custom Air Intake with UNI filter
larger fuel injector
Custom header and exhaust
Hunterworks 660 Rhino Machined Sheave kit
Gates C12 700 Rhino Belt
Slugged wet clutch
Weller Racing 660 Rhino billet middle drive gear support
That’s a far cry from just messin with the engine. Sounds like you have a few bucks in that motor. I bet it sounds and performs like a raped ape. Congrats. Don’t know if I’m willing to go that far but wanted a little bit of horse power and torque from stock. Thanks for the reply.
A picture of motor would be nice to show off.
  • 3 months later...
Slugged wet clutch
This is good to know after the exhaust mod I just manufactured for my Hisun 750. Wondering if I will get some fault codes later from the mods. Will I be able to scan and clear codes with that software and cable adapters?
No one sells a tune that I'm aware of. With HUD ECU hacker you can adjust the fuel map and a few other limits.
You would basically need to play with it and adjust. Factory fuel map is set to meet emissions, prevent damage to the engine, and make it operate smoothly.
If the engine is in good shape you can likely get away with a little more fuel and a little more spark advance without any issues, but it's not a big displacement motor and there's no way to adjust the valve lift or timing so you're not likely to get more than a couple HP max, just not worth the effort without making other modifications.
    • By Tim n Deb
    • By Jon W
      looking around and cannot find and Stampede motors, the Havoc looks to directly bolt in, with exception of the larger displacment. has anyone looked into this further? seems to be a better option considering stampede engines are on backorder.
    • By SouthernGypsy
    • By se3388
      Steve.............
