Hi..my machine is hard to crank most times. Once it catches, it's fine but it takes multiple attempts and usually a jump start to make it start. Installed a new battery with same result. Is there a higher torque starter available? 2018 TBoss 500. Thanks in advance!
Best guess given the limited information is the starter wiring is to small. I have seen this in other Massimo models. Try replacing with #8 wire. To test If this will help,
use a fully charged car battery and jump with good quality cables directly to the starter motor terminal. Also, use a good ground next to the starter. Could also be a bad starter or other issues.
  • Thanks 1
    • By TapBoss
      So I’d been shopping for an enclosure for my ‘21 TBoss pretty much since I bought it. Then they came out with half doors and that’s the only one that I could find. Then the other day I ran across one on Amazon for half the price of anything else I’d seen. The link is below and I’m pretty impressed by how well it fits. There is one Velcro strap on the top of the door that doesn’t line up well with the roll cage, but I’ll work around it.
      https://a.co/d/09ACQ191
    • By AlphaSerenity
      Hello,
    • By mike28honda
    • By Nick Varnes
