Coleman u400 2021 won't turn over
Bought my coleman u400 from TSC last year, was running great. I live on a lake and use it almost daily to climb a pretty steep hill from my house down a path to the water. Last week was driving up the hill and it just quit. First thought was I'd run out of gas but it has almost a full tank of gas in it.  Have tried to get it to restart and the lights come on and it tries to turn over but won't catch. Checked the battery and tried to jump it just in case but it's not that. Checked the starter and it's good. Can't find the spark plug to even check that. I called the local repair guy in town and he told me he doesn't work on Hisun since it's all shit and I'd be better off burning the damn thing so that's been no help. Would appreciate any other ideas.
Explain the process on checking the battery please.
Not familiar with that machine but the owners manual should tell where spark plug is.
The battery needs to have a charge of about 12.6 volts to be considered good. Less than 12.2 and it probably won't kick in the starter.
The stator charging system is not the best.
Can you hear fuel pump?
Any codes on dash?
    • By wnc woods
      Is it possible to add a low gear to the Coleman ut400? If so please help. Ty
    • By DLJ
      Have a Hisun 800 it runs for about 35 minutes then stalls. Crank's over but has no spark. Let it sit for 15 to 20 minutes and it starts and runs again for about 35 minutes. Changed the CDI / ECU controller and still does it.
    • By buckrub
    • By MOTORHEAD1959
      ATV just clicks when trying to start. Battery is good, has a new starter, and all the wiring looks good. any suggestions on where to go from here? thanks
    • By ETHIEL
      Spark plug keeps fouling. after 10-15 minutes of running any ideas what to look fore
