2018 Hisun Sector 1000 Crew stalling but starts right back up. Please help!
By Mike Jenkins
I replaced the stator and now it will not start (run). It cranks fine, has fuel pressure, but will not fire up. I replaced the coil, no luck there.
By Prepper
By Grant
By Matthew Smith
2013 Bennche Bighorn 700 EFI
By rdborra
