On my Coleman ut400 I plowed the driveway it was fine went back out a little while later I released the parking brake the light went off I moved it about a foot the parking brake light came on and kept beeping but it moved fine. I’ve tried it in reverse and forward and push the parking brake and released it and the light is on and beeps when it’s in gear.
    • By Rusmis91
      thanks in advance
    • By mrpro
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Fmaxiron
      Thanks a lot!
    • By Dave Jones
      So with seat belt on  I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
