I sounds like it could be a loose or corroded terminal. When you start the engine, does the speedo kick up every time? I have 2021 Coleman 550 with low hours and the speedometer quit working while I'm driving. But,it kicks up to max and back down when I initially start it. I think that's telling me that electronic control unit is going through a test sequence at start up and the dash component is fine. I have a replacement sending unit but haven't installed it yet. Don't assume that your new sending unit is not also faulty. I don't know if there's anyway to test it unfortunately. Another thing I haven't explored are error codes and if they could shed any light on the problem.
    • By AlphaSerenity
      Hello,
    • By AaronD1982
    • By Burk
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
