Kubota RTV900 won't stay running
By Tim n Deb
By Flanman55
I have purchased a used Supermach700 (2008), It runs great after a new choke cable but. The temp sensor on the thermostat house is unhooked and can not find where it plugs back in. The fan has been un hooked from the sensor in the rad and cant figure out how it goes back together properly. The fan was wired to a by pass switch and i just always leave it on but would like to work it properly. I assume the sensor went bad and not changed.
any help would be great.
thanks
By KWinTX
By BigWave
Bigwave
By GunnersTacklebox
