Coleman UT400 Charging Issue
Popular Now
By Dave Jones
So with seat belt on I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
By Burk
By Mitch13
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
By Hunterman22
Can anyone please tell me or send a link as to how & where to hook up a code reader to my 2021 Hisun 500 Axis. I have a 6 pin to a 18 pin adaptor and the blue cord VAG KKL adaptor .Just not sure where or what to hook up to. Can I use your typical vehicle code reader or do I need to download something on a laptop or PC???
By Jeff freeman
