Hello I have a 2022 axis 7004x4 Utv after about 6 months it would start fine but sometimes it would stall and you have to crank it again and it would run fine I am wondering what causes this does anyone else have this problem. Thanks
  • Alex changed the title to 2022 Axis 700 Goes dead after cranking
  • Alex changed the title to 2022 Axis 700 Stalls after cranking
Just now, Grizz said:
Why are you changing my title
Because it was missing the machine info and you posted two topics that were the same. I combined them into this one for you.
Try resetting the computer.
Turn key on/off 5 times within 30 seconds. Making sure you hear the fuel pump kick on each time.
After the 5th time, leave off at least 30 seconds. See how that works for ya.
Could try changing fuel filter. My OEM filter had paint chips inside it.
Could try replacing the fuel injector. ( I still need to do that)
Try cleaning the air filter.
    • By Tim n Deb
    • By KWinTX
    • By BigWave
      Bigwave
    • By Ed Michael
      Subaru SxS.mp4
    • By Aaron Colona
      Just bought a brand new 760 about a month ago. I'm at 20 hours which the book says is when you need to change the break in oil.
      I must be crazy, but I can't find the oil filter. I've googled a million videos...everything seems to be 2019 or lower...and/or a 550.  They all show the filter easily seen by looking in past the rear passenger tire on the engine. There is absolutely nothing there on mine.
      1.there seems to be very little info if you Google a 760, or anything Massimo newer than like 2019.
      2. Does anyone have a current model year 760 that can answer my riddle for me?
