Hisun Sector 550C total electrical failure.
Go to solution Solved by todd93,
Hi, all! I. I'm new to the board, hoping someone could help me out! I have a 2020 Hisun Sector 550C that I bought new in 2021. Today, I took some stuff next door to my parents. When I went to leave, I turned on the key, heard the solenoid click, but no lights, no guage activity, no fuel pump, and no starter.
The battery is good, I checked all the fuses, they are good. Not sure if the relays are good, or even what to look for there. Is it possible that it's maybe a wire?
I'm really stumped on this one! Any help would be deeply appreciated! Attached is a pic of the fuse box layout. 20240519_163658.thumb.jpg.e50684d586ffbf635723f484355ba3a0.jpg
Todd
Just a quick update, I believe the problem is the main relay. This is not a serviceable part. It's not the small box with some fuses that some models have, it's one small relay plugged into a wiring harness. Weird thing, I happened to be walking by it, turned the key, and it magically worked! At least I was able to get it back home!
Relay sticking? Any corrosion visible? If it does it again give it a sharp tap with the bandle of a screwdriver and see if it resolves temporary.
Most relay failures I've seen are due to arcing on the contacts or corrosion from water getting inside. They're not well sealed.
  • Solution
Yes, I can understand that, and yes, I did tap the main relay quite a bit, it's quite different from normal relays... Honestly, I can get the cover off of a normal relay and visually inspect it... I'll share a pic of it, I ordered one off of Amazon, waited for it to fail again, replaced it, and no more trouble!
  • 1 year later...
I am having the exact same issue with my Hisun 750 Tactic ATV, not power to anything!   Started it to move it out of the garage, it ran for about 5 seconds then stopped, and now no electric power to anything.... all of my fuses check out good, with my multimeter.... I also have a new Main Relay on order from Amazon, waiting for it to arrive from China - hopefully that solves my issue. I want my unit to work.
    • By Rusmis91
      thanks in advance
    • By AlphaSerenity
      Hello,
    • By Eman85
