I have 31 miles on my new T-Boss 550. In order to start I put in nentural and the emerage brake on and push down on brake paddle, then trun ket and get nothing, with key still on I shift to reverase and the back to netural and it starts. Anyone know what is happening.
Thanks for your help
I got the fronts adjusted. I'm trying to raise the ride height in the rear, but my spanner wrench keeps slipping. Is there an easier better way? It's like there's too much pressure working against me to be able to twist the height adjusters. How can I relieve that tension to make them easier to turn? Â
Not my machine T boss 800 Massimo, < 300 hours will not shift at transmission, cable from selector knob is okay, cannot get it to shift at the transmission. Is there a safety one of the safeties I'm not holding in, I've tried the brake is something weird going on or is it Transmission problems.
