AI Overview
Ninety-seven (97) decibels is considered very loud and dangerous to hearing with prolonged exposure, roughly equivalent to a newspaper press, a loud nightclub, or a snowmobile. At this level, damage can occur after just 30 minutes, necessitating hearing protection
I bought a pair of Rough Country pod lights and it comes with a 3 pin plug(black, white and blue) I want to hook it up to a lit 5 pin rocker switch but I don’t have a clue what pins do I need to connect it to. I wired it to the keyed switch. Chat GPT as good as it might be does not know what I am asking. Any help would be greatly appreciated!
Hello all. Just bought a 2006 Joyner 650 SAND VIPER and have been going through it quite a bit. Have a hard time finding parts for it so I've been going with a lot of universal parts including the trailing arm bushings I'm swapping out for 1.5" poly bushings with sleeves. Original bushings did not have inner sleeves which is terrible design flaw. I am also having trouble with the oil warn light coming on after replacing oil and driving it a week it intermittently pops up. No pressure gauge but I have one on order. What type of oil do yall run I put 10-40 in it but heard 15-30 is recommended by manufacture? Also in need of rear wheel bearings but the part compatibility list stickied in the forums suggests part numbers for sand spider however the viper is similar frame to the 800 series with the trailing arm style suspension in the rear. I will dismantle the hub this weekend to take some measurements just seeing what general knowledge is out there. Thank you
