I bought a pair of Rough Country pod lights and it comes with a 3 pin plug(black, white and blue) I want to hook it up to a lit 5 pin rocker switch but I don’t have a clue what pins do I need to connect it to. I wired it to the keyed switch. Chat GPT as good as it might be does not know what I am asking. Any help would be greatly appreciated!
Did the lights come with any instructions? If not, go to their website where they will have instructions, I looked. They also have a support phone line, that would be your best resource. They apparently have a wide selection of lights and may have various wiring options.
    • By jertex
      I have two questions:
    • By OBL
    • By MilSurpYinzer
      Anyone decent with electrical work that knows a good tutorial on how to make my running lights switch off all together but also turn back on when I need too? I'd assume that my lights are hard wired to the battery or the fuse panel.
      Vehicle is a Kawasaki Krx 1000
      I'm looking to ad IR driving lights for night vision and short of just putting black tape over the lights I feel this would be a more efficient option and it would be cooler.
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
    • By Roadstar515
      Does anyone know of a bypass switch or controller. They make one for Polaris which installs into the harness that makes the ECU think it’s hooked up in normal position allowing vehicle to operate normally as if you are wearing seatbelt.
