I'm in need of ramp assist for my utv trailer. I found a few, just ckg to see if anyone here knows anything about which is good,or better.Or has found & used different one. I can't lift much or bend very well, sooo, I need something to help? Wife won't lift it either!!! : )
Quig
check these out
http://www.easternmarine.com/Double-Barrel-Trailer-Gate-Assist-RA27C--0/
http://www.easternmarine.com/BUYERS-EZ-Gate-Trailer-Tailgate-Lift-Assist-5201000/
Was told by very wise member, that he almost missed my post, I put it in general discussion, utv forum,, "sorry" :unsure::)
Thanks for pics,that could well be my next project. not sure yet, have to have shoulder,& neck surgery, might not be cranking anything.
I was thinking, since you have to have tail lights on your trailer, maybe some method can be rigged so that you turn your tail lights on, then you have a switch that steals the power from the lights and runs a motor to run the winch up and down. It would be simple electrically, but finding a light weight power winch could be difficult. Any one out there know of such a thing?
Kinarfi
Just throwing a cheap option out there. Could you use your trooper winch?
Thats pretty smart thinking, But, I'm really leaning towards 120.00 spring loaded example, really simple.. Thanks though,,Quig
Guest Lenny
I would think you could use the gas springs. They are cheap and available in most any length and force while small and simple to hook up.
Well, I went with the easy lift,,,http://www.easternmarine.com/BUYERS-EZ-Gate-Trailer-Tailgate-Lift-Assist-5201000/
Got it installed, works great!! No more groaning & moaning. Very easy to install. Even "Quig" did it!! :rolleyes: :rolleyes: :rolleyes: :rolleyes:
    • By jertex
      I have two questions:
    • By Cliffampranch
    • By Firewalker918
    • By Eman85
    • By Jeff freeman
