I know of at least one Trooper owner that blew the front diff. I would jack the front up and rotate the wheels and see if I could locate the source of the clunk before I got too alarmed. Check diff mounts, CV joints as well as the diff itself. Sound can travel so could even be the front driveline. Good luck!
rocmoc n AZ
Devildog,
One last thing to check before you pull the diff. Make sure the locker cable is fully engaging and disengaging. If only partial, could be slipping on the edge of the teeth of the pinion nose. Adjust or disconnect the cable and make a test drive.
rocmoc n AZ
    • By jertex
      I have two questions:
    • By OBL
    • By Thearm
      I have a 2018 TW450 that runs fine on flat ground but dies out when under load going uphill. Changed the gas filter and spark plug with same results. Letting it set for a few minutes it will run until it hits a incline. Belt is not slipping, but the engine just dies out and doesn't even want to run in neutral. Any ideas as to what I can try is appreciated in advance. Also only run non-ethanol for fuel.
