I am going to put in my pitch for a weight saving pinned thread again. I just received some Lightforce 140 Lance headlights I ordered. They are about 1/3rd the weight of the factory headlights.
Lenny has saved some significant weight by removing the front driveshaft donut.
I could post up the numbers that I have written down for the rear cage & spare tire.
I could post the weight of the factory shocks. Airshocks could save you tons of weight. Even my fox shocks are lighter than the factory shocks by a few pounds.
If you remove the factory lightbar (I do very little night riding), there is 15-25 lbs. Or, if you build a light bar like Kinarfi you would save alot of weight.
Guest Lenny
I like that idea. Of the many things I have done, one is to replace the steel plates under the seats with 1/8" aluminum. That saved 10 pounds.
Plastic off road lights to replace the stock lights. More about being able to see at night, but still a good weight loss. Took off the winch and wiring, there's nothing to hook it to in the sand anyway.
On the add side, welded on tabs for the flag, and mounts for the flashing lights.
  • Popular Now
    • By Rmillerdesigns
    • By KMP
      We just bought our 1st side-by-side and wanted to get tips on maintenance items we should address immediately for our 2015 Arctic Cat Wildcat Sport 700 XT.  We are truly beginners and welcome any and all suggestions.  Thank you, we appreciate your help!
    • By NewtoUTV
      I am trying to deal with the shifting issue this piece of ..... has.
      I have the part that Jose made from this video https://www.youtube.com/watch?v=SPU22uKW01Y&t=13s
      I have the engine loose except for the drive shafts.  I have no idea how to take them apart from the engine, looked for videos or directions and have not found anything. (maybe I am not using the correct terms when searching)
      Looking for help on how to take this apart, so I can lift the engine out and work on it.
    • By HighSon
      Locking gas door.
      Rear view mirror.
      Folding armrests.
      Folding rear seats.
