HELP-Trooper T4 won't start
By donny
By LongSun
By Steve B
By Nathon S.
I have a Bennche 700 EFI Bighorn. I’ve recently been unable to get it to start. After a little troubleshooting I realized my fuel pump was not pumping fuel. This weekend I emptied the gas and replaced it with new. I replaced the fuel pump, fuel filter and fuel injector. I also replaced the battery, spark plug and made sure all my fuses and relays were good. I have confirmed that the float on the fuel pump is not obstructed. The UTV is about 12 years old and has less than 100 hours on it. It has not run in over a year. Not sure whats going on?!? After doing a little reading I'm leaning towards it being an issue with the ECU or perhaps a faulty wire in the wiring harness. Anyone have any ideas on where to start looking or what I could be dealing with? Any help is appreciated, thanks in advance!
By Hi sun 500
hello everyone, i just joined this forum to try my luck, few days ago i bought an old (dont know exactly), 2011/14 hi sun 500cc ""carburated"", was not running at the time, but i fell was a good deal and decided it to bring it home to play with it, this is the issue, i bought and installed a new carb, and pump, i repositioned the battery location and upgraded to a "car batt", reconnected the fuel lines and started it, but it only runs with the choke ON, i checked the bowl, it does have fuel,but for some reason wont inject it to run, i came across a video that say that ""the body small tank had to be connected for the cart to run" (was deleted when bought), sure enough i got it to run sporadically , but the so called ""small body tank'' often runs out of fuel and wont refill itself , i had to couple times do it manually, so how does that small tank works ?..what does it do?..and why if bypass it , the cart wont start?....any help?..thanks so much!!!
