When you remove the schrader valves on the joyner shocks, what thread is the hole?
I'm trying to ad a remote pressure tank, hoping to be able to easily adjust the shock nitro pressure (using my local welding gas). Don't want to remove the fitting to find out - filling these things is a major pain here in Panama.
Anyone buy an aftermarket main switch, and if so, which one works best?
Mine just burned the internal contacts. I think I can clean them, but it does look flimsy and would prefer something beefier.
Winch relay - which would anyone recommend?
And an old, but still important unanswered question: Has anyone found aftermarket 2 or 4 pot brakes that would work with minimal changes? Brake pad area is soooo small on these machines.
THANKS FOR ANY AND ALL HELP!
Yeah, I got a champion 4000 lb winch too, but in this climate the humidity kills everything. The switch box fused together and damaged the kill switch before the fuse kicked in...
Yup, New 500 amp kill switch ordered on ebay;
New 40 amp breaker ordered ebay
checking relay tomorrow
found braided line here in panama - no easy task, plus the guy didn't want to sell it cus he didn't have fittings, or so he says. Bought it, plus bought fittings, and will be putting everything together in the next few days. Once done I'll post pics
    • By Silent3923
      Been waiting over a month and a half for a transmission from bobcat,  they claim the polaris transmission is different.   Can anyone verify that???
    • By nrggaragebuilds
    • By mrpro
    • By AaronD1982
