help with no start T-2 1999
By JOYNERPARTSGUY
I'm thinking about parting out my 2 Joyner's. Both have less than 500 miles. I would also consider selling whole. I have titles for both and have owned them since new. Located in northwest Florida. I'll be in Gatlinburg , TN for Christmas if someone needs a heavy part delivered Trooper engine has rust on the cylinders and probably won't turn over at this point due to Florida humidity. The sand spider has a broken input shaft in the rear end, so it needs a new (cheap) input shaft and seal. It hasn't been cranked in a couple years. Both are complete.
By monkthumper
By Gerald Dillman
By Ed Michael
Subaru SxS.mp4
