Hey guys, I picked up a used slave cyclinder with a bracket on ebay, I believe it was off a trooper. I alreay had a 7/8 CNC master cylinder off a class 1600 off road buggy. The bracket does fit the hols in the tranny but won't work on my commando because of the stack exhaust. Does anyone have some pictures of how there slave and master cylinder are mounted. Fabrication is not a problem but with the clutch angle and getting the master low enough for the proper throw it is pretty close to the tie rod. In a violate nose dive not sure if it would hit.
Does anyone have any picture of the hydraulic clutch set up. Moutning of slave cylinder and master cylinder. Having trouble finding a suitable location to mount the master cylinder and have the right angle for the push rod. Please help.
  • Popular Now
    • By RBonds007
    • By Jeff freeman
    • By Timbo
    • By Outlaw Redneck
      Hello all. I have a 2005 Joyner sand spider 650 with the dreaded broken output shaft on the transmission. I got ahold of a 2007 joyner commando 650 for cheap that had a bad motor but a good transmission. I got it because everything i read said that the transmission would work but it seems that it will not. Due to the commando being 4x4 it has a selectable locker and a small ring gear using a "idler" gear to turn the ring gear which make the output spin the wrong direction. Is there any way that I can make this thing work? I really dont want a commando,  I like the buggy but if the trans wont work then I can only put my motor in the commando. Any help would be appreciated. I have the ring gear from the original trans but the shaft is broken and the shaft from the commando wont fit the ring gear it doesn't appear.
