just received an email back from SB claiming that they have a 360 watt power steering kit .... what do you all think i sent them one back wanting manufacture and all of the motor it would be interesting if it was a 360 watt motor it should turn the trooper even with the lockers locked in ... super at is only a 220 and 650$ SB 360 watt claimed and 1200 .... so for the extra watts if true i would do it possible that and how do the ones from super atv steer with lockers locked ...
no shit thats awesome i m all about getting the most power and easy drive ability it is a true work out driving the trooper locked up lol not that i mind i m 27 .... but it would be nice to go slow and not get a full arms and chest work out
i talked to franky from SB there computer are now water proof all brackets bolt right up and i m going to to get the new up graded rack if i get it but will have to buy a new lower steering shaft because the size is now larger it is suppose to be done this week
      Has anyone installed the power dump on a Kioti K9? If so, does it eliminate the safety lock? Does it work well?
      Thanks for your input
    • By Edelbrock
      Thoughts?
    • By CapnWalleye
