rear diff
Go to solution Solved by Kinarfi,
ok well my locker was nt working properly so i tore everthing apart and found that the two gears that was side by side where the gear slides over top of them to engage it had a lot of play in it took the bolts out of the ring gear to find out that 2 bolts was snaped and that most of the rest of them was worn or deformed .... what is the upgrade kit consist of and i m going to get new bolts tomm from tri corps or fasten all ...i have another rear end that i am using parts from that the two gears are very tight on
Yeah get new bolts & lock tight the hell out of them. If you can safety wire them also that would be even better if you know how to properly safety wire. The kit has upgraded bolts which Lenny machined the heads on and shims. The biggest upgrade being the bolts & liberal use of high temp lock tight.
The stock bolts wiggle loose then shear off. If they stayed tight no one would have issues most likely.
red lock tight i got napa to order the new bolts today and yeah i m pretty sure i can drill some holes threw the new bolts and wire them up .... i was disappointed when i found out they did nt have anything harder than a 8.8 the only ones i could find in the right thread was to big of a head ....
Are the head 10mm and shallow? Regular bolt heads won't clear, search for McMaster and follow them, I did a right up on what you need and how to grind the heads down to clear, Red lock tite is good, but yellow is a better. Find the post that says to use shanked bolts and there are instructions in there too. good luck.
Jeff
the heads where 13 mm and i had to cut the inside of heads off of them to make them all clear properly i was going to use a socket head bolt but could nt find any in the right thread count
those read as a 1.25 mine was between a 1.0 and a 1.20 the 1.25 would only start to thread it about half ways and then become difficult to turn by hand the 1.2 and 1.0 threaded in all the way is this the same case with yours just a ? not doubting anyone
it is an 2008 as well and i tried tri core ... fastenal and napa .... IRC in ohio is where i got the right bolts .... but the head was a 13 mm vs a 10 so i had to cut it down
sorry i did nt take any pics it is back together and locking in and out and running smooth
Get some loctite too http://www.utvboard.com/topic/2795-tapered-roller-bearings/?p=16079 this is what I used on my bearings, but it's probably good for your diff too.
And while I'm here, may I suggest that every time you have a wheel of the ground, push and pull on the top of the tire and see how much play you have.
IMHO the two worst problems with the Trooper are the diffs and the wheel bearings, get the roller bearings, repack the grease and loctite them in place
ok was just wondering have you had any problems with your since you ve done it how often do you check it ... i m going to change y oil tomm and check for any metal and take it back aprt if needed
I had a couple of bearing fail, but I got right back on the road because I had most of a spare and it had the right parts in it. I like the idea of the shank on the new bolts extending through all the separate pieces so you don't have a place for shearing to start, plus this is the strongest bolt you can buy, 12.9, and NO, I haven't had any problems since. I think if you get thing tight and loctited, you can put it on your do not worry list, you did read about Lenny's instructions to sand all mating surfaces radially, right?
Make sanding scratches on all the flat surfaces that mate up so the loctite has little groove to go into and sand from center out wards on both mating surfaces.They don't need to be deep, just visible.
    • By SkyPilot56
    • By A P
    • By clint501
    • By D MAYNARD
                                    Thank You,
                                  D Maynard
    • By tuell
      Hi everyone I have a 2016 hisun vector 550 with 1320 miles on it I recently replaced the clutch the bell the belt the one way bearing basically everything inside the primary and drove approximately one mile my side by side just stopped pulling... no noise no smoke nothing the belt is still good but it's like the transmission will not engage in any gear any help would be greatly appreciated.... I have lifted the rear end and started the side to side put it in gear Wheels do not move but you can turn them by hand
