2020 400 Coleman HiSunUTV 393cc Side by Side Coolant Leak
By AaronD1982
By lincolnsq175
I have a 2020 coleman ut400.
Any info is appreciated.
By rdc
By 180gtr
Parting out a rolled Sand viper 1100. I will list some of the parts I have, otherwise ask me if there is something specific you are looking for. I am selling everything I have for $800. I am located near Glenwood Springs CO.
SOLD ITEMS, I do not have these items.
Wheels
Tires
Engine
Transmission
Axles
Shocks
Control Arms
Things I have....These all came off of the running engine. I have video of it running if anyone needs to verify that.
Throttle Body $90
Starter $150
Alternator $150
Fuel rail, injectors, fpr $100
fuel pump $70
Map Sensor $50
Full set of Guages $150
Exhaust w cat, O2 SOLD
Ignition Coil - SOLD
Wiring harness and ecu SOLD
Radiator, shroud, elec fan, overflow tank $200
Fuel tank w sender $150 Has dent at base of fuel neck, no leaks
I have a box full of misc bolts, nuts, etc.
I will sell the Chassis or Frame alone for $200. The chassis is in pretty good shape, needs some cage repair and 2 areas straightened where control arms mount. If anyone had an automotive frame machine it would take a few hours.
That would include....
Brake calipers, lines, pedal, master cyl, E brake assy,
Steering shaft, wheel
Ignition switch, key
Light bar frame, 2 lights
misc hardware, spindles
2 hubs, rotors
Engine mounts
Throttle pedal, cables
Shifter, cables
Clutch master, pedal
I am sure I am forgetting something.
I am parting this out of ebay right now, I just picked up another project and could use the room. No I will not take less than $700 for all of it or $200 for the frame. I do not need to sell it, I will make far more parting it out but would like the extra space in the garage.
If interested I also have an 07 1000rr engine setup I would sell with the buggy for $650.
By Timbo
I never see videos of hear of people taking these things to the big trails. Do you ? I just got one and want to.
