So while building my cage I made one bend a couple of degrees over. It was literally 3 degrees off. So I wedged it in my tube bender, had my wife sit on it while I pulled like hell, and several attemps, and got it within one degree. So with my wife (130lbs) and me pulling my 185lb ass off all it left was a couple of small dents in the 1 3/4 .095 wall hrew I am using for half of the cage. The other half is .120 wall DOM.
So once I got done getting it to shape I thought to myself that I need to see what happens if I try it with the stock cage. I wanted to know if all this effort is worth it. Well, I finally got around to it today. This is what happened with just me pulling (no wife for extra leverage) and with half my effort:post-867-0-44270600-1396914922_thumb.jpg
If you ever had a endo in a trooper you would not walk away. Can it handle a flop or a slow sideways rollover... Probably, but an extreme impact and it will wrap around you like a street taco.
wow Ya I just had the front and rear welded together if I was as crafty as you or some otheres I would stotally rebuild it I was shocked how thin it was the new tunes I added are 2-3 times thiker and feel great with the xtra wieght off the back
Yeah, when I take my rear seat off mine is so much less tippy. I think I estimated about 85lbs for the stock rear cage and spare tire. I run superatv dominator tires and don't even work l worry about running a spare tire. The stock tires are paper thin.
  • Popular Now
    • By Paul O
      I boughtba new Hisun HS 500. When I press the red 4wd button the icon over the front differential on the display flashes. Is this normal?
    • By TimsBrickHouse
    • By S.Petrucci
      2015 massimo gunner 250, 100 hrs shown use. Problem: antifreeze does not go into the tube/engine when attempting to add thru the radiator cap?  (The overflow reservoir shows “low”, so i believe add’l fluid is needed). Any advice appreciated!
    • By 2coil Fox
      SO NOW what do owners do?  I own a 2021 Tracker SxS 800SX LE —— perfect condition and very pleased with it BUT concerned that Textron discontinued building them !  What are other Tracker Off Road owners hearing & doing for Service etc..?
    • By D MAYNARD
                                    Thank You,
                                  D Maynard
