2015 massimo gunner 250, 100 hrs shown use. Problem: antifreeze does not go into the tube/engine when attempting to add thru the radiator cap?  (The overflow reservoir shows “low”, so i believe add’l fluid is needed). Any advice appreciated!
2015 massimo gunner 250, 100 hrs use. Problem: when attempting to add antifreeze, thru the radiator cap, of course, the a/f will not go into the radiator?  (the overflow reservoir is at “low”, so more is needed?  Also, when in use, the temp gauge shows normal temp, but never “hot”).  Blockage?  Any advice appreciated!
    • By Adrian Domingues
      Thanks for your help
    • By AlphaSerenity
      Hello,
    • By jertex
      I have two questions:
