1100 Exhaust System Upgrade
By Tom Gorski
Just bought a 2014 Volunteer. Can anyone tell me what parts have to come off to change the oil and filter. I can see them but I can't figure out how to access them. Thank You
By Bbicon
I have a 2014 odes 800 dom. I have a wire in the same harness as the fuel pump plug ( just before it ) and it is not connected to anything t has a connector and a little brass connector on the end , I was wondering if anyone could tell me where it goes to
By Greg Kilgore
I'm 99.9% sure head gasket is blown.
Don't have coolant in oil. That a good thing. But think coolant is getting in combustion chamber.
I did compression test.
Got 120psi walked away. Came back to 105psi 15 minutes later.
How hard is it to replace?
https://youtu.be/N31mOtOPuKI?si=nSnuF4-weRU2T10t
Advise?
By Mike McDonald
I have a 2014 Intimidator and need brake pads and calipers. The price for pads and rotors are outrageous through the dealer. I have heard Intimidator used the brake assembly from a compact car when first building these UTVs.
• Can anyone tell me of a less expensive source to buy brakes for Intimidators from, or
• Can anyone furnish information on what make and model vehicle Intimidator used their brakes from?
Thanks so much for any support you can provide me on this topic.
Mike
By tskm
Tom
