Hey guys please did a 100 miles on my trooper this weekend I noticed that sometimes I hit the brake the pedal seemed low or soft and I noticed that sometimes after braking a little hard the next time I hit the brakes the pedal was hard. No leaks still got meat on the pads I'm assuming maybe internal master cylinder leak any ideas has anyone replaced a master cylinder and with one
My guess is that the caliper plunger is getting pushed back a little more than usual and that makes the pedal feel soft because it has to push the plunger back to normal and the onto to the brake.
This could indicate that there is play in the wheel bearing, jack the wheels off the ground and wiggle the tires.
I do have a little play in my front bearing but I have talked to Casey at jmc a few times about it and he feels like I am Probally with in spec. When I take the wheels off and grab the rotor the play is minumil and no grinding or noise from the bearings I have tried to get the bearing tighter nothing has worked and they r tappered bearing last time I replaced one there wasn't much difference
That would be my guess. But isnt both front and back seperate with 2 master cylinders? But they are pinned togather at pedal? So wouldnt it have to be both front and rear issues to lose pedal ? If not couldnt it be a rear?
Charlie...your brakes should be 1 master supplys 1 front,and the opposite side rear brake..the other the opposite front/rear combination...kinda like an X ..makes them fun to bleed,normally have to remove 1 of the "push rods",bleed,then switch sides. A common problem is when the master cylinder piston does not return all the way back (up against the circlip) sometimes just cleaning out the "gunk" in the end of the master will allow it to return...bigdan,have done a number of heaters,where did you plumb in and out ? what are you using for a heater ? Hardy
I attached one line to the 5/8 hose beside thermastat and the other to the front water pump hose where the tee was.Im using a summit racing after market heater. I have it mounted high at the top my cabin. I am most certain I have a air pocket.
sounds like you already know the problem...the input to the heater is the "almost" 5/8 line,not exactly sure where you returned,but sounds right...that circuit kinda bypasses the rad and themostat...the air lock can be a bit#% to get rid of...can you get your core lower (below head /rad upper hose) at least to bleed out air?...even loosen clamp(s) at heater core while running (carefully) to allow air to escape?...just my 3cents...Hardy
Thanks! Your defiantly right. It's not 5/8 dam metric shit. I think I might put in a bleeder in the line. I would lower the unit to bleed it out but I like to make things so I don't have to fool with it again. I might use a Preston flush kit to use as a bleeder.
Thanks Hardy!
Charlie,its awkward...but if you look where the brake "push rod" goes into the master cylinder,you can see the end of the piston...when the brake pedal is released,the piston should come all the way towards you untill it stops right against the snap ring if it doesnt come all the way back it wont allow fluid into your master from the resevior ...sometimes all it takes is to blow the dirt etc out from the end and work back and forth a little to get piston to come all the way back...just my 3cents...Hardy
    • By hetovi
      Hi everyone,
      I’m considering installing a soft cab enclosure on my vehicle and wanted to get some insights from experienced users.
      I’m particularly curious about which materials hold up best in different weather conditions and how to properly secure the enclosure to prevent leaks or wind noise.
      Are there specific brands or models you recommend for durability and ease of use?
      Also, how do you handle cleaning and maintenance without causing damage?
      Any tips, tricks, or common mistakes to avoid would be incredibly helpful.
    • By jugliner
      I have a fuel injected UT400 that will start and idle, but surges and sputters at higher speed.  It has been sitting for 2-3 months and was fine when parked in garage.  I assumed it was a fuel/air problem and pulled the throttle body and cleaned it up.  I've ended up replacing the injector, IAC valve, MAF Temp Pressure Sensor, and fuel filter.  I've also checked the spark plug, Still surging.  I reset the ECU after every component swap.
      I plan to pull the throttle body again and look evrything over for any visible leaks, etc.
      Any suggestions would be appreciated on next steps.   The problem developing after sitting makes me think it should be something simple, but I'm stumped.  BTW the fuel was fresh and treated with Stabil.
      Thanks.
    • By AlphaSerenity
      Hello,
    • By jamesxevan
      I’ve been eyeing a Hisun 500 soft cab enclosure upper doors setup for my UTV, but I’m really not sure if it’s a smart move. The idea of doors and some protection sounds appealing, but I worry they might just be a flimsy afterthought — weak zippers, thin plastic windows, maybe leaking or fogging when wet or cold. What good is “protection” if it doesn’t seal well? Also concerned about ventilation: with soft doors, does the cab get too muggy or stuffy?
      Anyone here use soft-cab doors on a Hisun 500 — did they actually hold up for real riding conditions, or did you end up ditching them for hard doors (or no doors)?
    • By dogfood
      Hello -
      New here - and looking hard at a 2026 Mule Pro-FXT 1000.  My wife insists we'll be going with the Platinum Ranch, because in her words, we already saved $ by not going with a Honda 1000-6.  Ready to pull the trigger on this ... almost.
      We were looking at the factory soft cab, but then realized this won't work with the standard hard top, as the soft cab has dual back windows to accommodate the 3/6 folding seats.  However, we like the hard top.  So recognizing there's a lot available in the aftermarket world, does anyone have suggestions relative to an aftermarket soft cab (sides, rear window, etc.) that will work with factory hard top, windshield and doors - and also allows for a (relatively) simple 3/6 seat conversion?
      dogfood
