Brakes.....
Popular Now
By hetovi
Hi everyone,
I’m considering installing a soft cab enclosure on my vehicle and wanted to get some insights from experienced users.
I’m particularly curious about which materials hold up best in different weather conditions and how to properly secure the enclosure to prevent leaks or wind noise.
Are there specific brands or models you recommend for durability and ease of use?
Also, how do you handle cleaning and maintenance without causing damage?
Any tips, tricks, or common mistakes to avoid would be incredibly helpful.
By jugliner
I have a fuel injected UT400 that will start and idle, but surges and sputters at higher speed. It has been sitting for 2-3 months and was fine when parked in garage. I assumed it was a fuel/air problem and pulled the throttle body and cleaned it up. I've ended up replacing the injector, IAC valve, MAF Temp Pressure Sensor, and fuel filter. I've also checked the spark plug, Still surging. I reset the ECU after every component swap.
I plan to pull the throttle body again and look evrything over for any visible leaks, etc.
Any suggestions would be appreciated on next steps. The problem developing after sitting makes me think it should be something simple, but I'm stumped. BTW the fuel was fresh and treated with Stabil.
Thanks.
By AlphaSerenity
Hello,
By jamesxevan
I’ve been eyeing a Hisun 500 soft cab enclosure upper doors setup for my UTV, but I’m really not sure if it’s a smart move. The idea of doors and some protection sounds appealing, but I worry they might just be a flimsy afterthought — weak zippers, thin plastic windows, maybe leaking or fogging when wet or cold. What good is “protection” if it doesn’t seal well? Also concerned about ventilation: with soft doors, does the cab get too muggy or stuffy?
Anyone here use soft-cab doors on a Hisun 500 — did they actually hold up for real riding conditions, or did you end up ditching them for hard doors (or no doors)?
By dogfood
Hello -
New here - and looking hard at a 2026 Mule Pro-FXT 1000. My wife insists we'll be going with the Platinum Ranch, because in her words, we already saved $ by not going with a Honda 1000-6. Ready to pull the trigger on this ... almost.
We were looking at the factory soft cab, but then realized this won't work with the standard hard top, as the soft cab has dual back windows to accommodate the 3/6 folding seats. However, we like the hard top. So recognizing there's a lot available in the aftermarket world, does anyone have suggestions relative to an aftermarket soft cab (sides, rear window, etc.) that will work with factory hard top, windshield and doors - and also allows for a (relatively) simple 3/6 seat conversion?
dogfood
