For all around driving, I like my 27X8.5R14LT General AT Grabbers, but you need to get another set for front wheels so you have the same all around, I don't want to play in the mud,so these work great. They do ok in the sand and great on dirt or paved roads.
    • By Sammy
    • By Eman85
    • By MilSurpYinzer
      Anyone decent with electrical work that knows a good tutorial on how to make my running lights switch off all together but also turn back on when I need too? I'd assume that my lights are hard wired to the battery or the fuse panel.
      Vehicle is a Kawasaki Krx 1000
      I'm looking to ad IR driving lights for night vision and short of just putting black tape over the lights I feel this would be a more efficient option and it would be cooler.
    • By hetovi
      Hi everyone,
      I’m considering installing a soft cab enclosure on my vehicle and wanted to get some insights from experienced users.
      I’m particularly curious about which materials hold up best in different weather conditions and how to properly secure the enclosure to prevent leaks or wind noise.
      Are there specific brands or models you recommend for durability and ease of use?
      Also, how do you handle cleaning and maintenance without causing damage?
      Any tips, tricks, or common mistakes to avoid would be incredibly helpful.
    • By kmiller7351
      Trying to get running a 550 Colman running but I think head gasket went bad. Do i just replace with new gasket, clean up and replace or is there more to it?
