08 T2 starting issues
my son hooked up my jumper box backwards after a dead battery condition. I have gotten my trooper to start only a couple times after this. I did a lot of visual inspections relay testing etc. so I pulled this thing out of the garage and hasn't been started in over a year. I purchased a new battery and installed it and it started on the first crank. I drove it around for awhile shut it off and now I'm dead in the water again it wont start. does anyone have an idea whats going on here??????????????????
pull your fuse box off the wall behind the driver seat check for burnt wires also test and see if you have power at the starter and that the stater gets signal when you attempt to start it could have burn out the solenoid I am putting a new stater in mine
    • By TPlummer
    • By Kingfish
    • By John Gubancsik
      I'm having trouble finding a replacement battery for my UT400.  Has anyone bought one and where did you get it?  Thanks.
    • By Woody77
